MMOEXP ARC Raiders: Beginner's Guide & Essential Tips
Сообщение Joenwalker » 20.05.2026, 09:19 »
Scavenger's Intuition: Faster search speed = more loot and XP.
Base (The Roost) Upgrade Priority:
The Rooster: Your #1 priority. Provides passive material income every raid.
Weapon Station: Unlocks new weapon and attachment blueprints.
Medical Lab: Unlocks better healing items and shield chargers.
Refiner: Converts common materials into rarer ones for high-tier crafts.
Part 6: Combat & Survival Mechanics
Health > Shields: Shields only provide damage reduction, not complete blockage. Damage "bleeds through" to your health for ARC Raiders Coins .
Heal First: If your health is low, use a bandage before recharging your shield.
Arc Power Batteries: Loot these from defeated ARC units. You can consume them mid-raid (Q key) for a quick shield recharge. A crucial emergency tool.
Extraction is Everything: All that shiny loot means nothing if you die. Evacuation points (elevators, subways) are loud and draw attention.
Secure the Area: Find cover and watch all angles before calling the evac.
Last Hope: You can crawl to an evac point and activate it while downed. Hold on until the transport arrives!
Part 7: Advanced Movement & Tips
Stamina is Life: Avoid spamming the combat roll; it drains stamina quickly. Only roll if it guarantees you cover.
Adrenaline Injectors: Use these! They provide an instant stamina boost and increased regen. Essential for escapes or pushing.
Fall Damage Management:
Ledge Grab: When near an edge, press your vault key to grab on safely.
Rolling Landing: Press roll just before hitting the ground to mitigate most fall damage and maintain momentum buy ARC Raiders Coins .
Resource Management:
Seeds: Don't discard them. Trade them with the vendor Celeste at your base for materials.
Recycling: Dismantling gear in-raid yields fewer materials. Bring stuff home to recycle for maximum returns.
Resource Tracking: In crafting menus, you can "track" a blueprint. Needed materials will have an eye icon in-raid, making scavenging efficient.
Final Pro-Tip: Network Stability
A smooth connection is non-negotiable. High ping can cause delayed shots and rubberbanding. Consider using a game accelerator like GearUP Booster to ensure you're connected to the optimal server region for the lowest latency and a stable experience.
You're now ready, Raider. Remember: move with purpose, fight with wisdom, and always have an exit plan. Get out there, scavenge, survive, and upgrade. Good luck!
Joenwalker
Байк: no
