How to Obtain and Craft the Kromede Longsword in Aion 2
Сообщение Goldener » 31.12.2025, 08:40 »
The Kromede Longsword is a unique sword in Aion 2 that is specifically designed for the Templar class. It’s a highly sought-after weapon due to its solid stats and utility in both PvE (Player vs. Environment) and PvP (Player vs. Player) gameplay. The sword is known for its strength, making it a popular choice for many Templar players aiming to enhance their combat effectiveness.
How do you obtain the Kromede Longsword?
Where to find it?
The Kromede Longsword can be acquired as a world drop, which means it’s not tied to a specific quest or boss drop, but rather it has a random chance of dropping during your regular gameplay. This makes it somewhat rare, but not impossible to obtain if you engage in enough combat around the game world.
Can you buy it from other players?
Yes, you can buy the Kromede Longsword from other players. If another player happens to get a drop, they may choose to sell it on the marketplace. It’s worth noting that the price can fluctuate based on server economy, but it can be sold for up to 27,970 gold in the marketplace, making it a valuable item. If you’re not lucky with drops, buying it may be a faster, albeit more expensive, route.
How do you craft the Kromede Longsword?
If you prefer crafting over purchasing or relying on random drops, you can craft the Kromede Longsword using the following materials:
Expert's Splendent Orichalcum Cloak x1
Artisan's Refining Stone x2
Pure Orichalcum Ore x3
Pure Odyle x2
This craftable method requires you to have access to a crafting station and some knowledge of the game’s crafting system. Generally speaking, gathering the required materials will take some time, especially since Pure Orichalcum Ore and Pure Odyle can be rare resources. If you’re planning to craft the sword, make sure you have a strong farming routine to gather these materials, or alternatively, you can purchase them from other players.
What are the stats of the Kromede Longsword?
The Kromede Longsword has the following stats:
Item Level: 57
Attack: 232 - 290
Accuracy: 150
Critical Hit: 50
Block: 200
PvE Damage Boost: Increases damage output against enemies
Manastone Slots: 4
How do these stats benefit you?
For Templars, the Kromede Longsword is designed to enhance both offensive and defensive capabilities. The sword’s attack range (232 - 290) makes it strong for dishing out decent damage in battle, while the accuracy of 150 ensures that your attacks will hit more reliably against enemies. The critical hit stat of 50 further boosts your damage output, which can be especially useful during intense battles where every hit counts.
The block stat of 200 is an important bonus for Templars, as they often act as tanks in group settings. This stat improves your ability to block incoming attacks, making you more resilient in both solo and group combat. The added PvE damage boost also helps in increasing your damage when fighting NPC enemies, making it a great choice for PvE-focused players.
Manastone Slots: With four manastone slots, you have plenty of room to enhance the sword’s stats further. Most players will use these slots to increase attributes like Attack Power, Critical Hit, or Defense to tailor the weapon to their specific playstyle.
Is the Kromede Longsword worth it?
Is it worth crafting or purchasing?
In general, the Kromede Longsword is considered a good weapon for Templar players, especially at the level it becomes available (level 57). The combination of decent attack stats, accuracy, and block bonuses makes it versatile for both solo and group play. If you’re a Templar looking for a sword that will serve you well in both PvE and PvP, this weapon is definitely worth considering.
For many players, obtaining the sword through drops can be a challenge, but if you’re patient or have the resources to craft it, the Kromede Longsword will provide a solid upgrade for your character.
Should you buy it from other players?
If you’re not up for the grind of crafting or waiting for a drop, buying it from other players can be an efficient option. However, keep in mind that the price can be steep, especially if demand is high on your server. You’ll need to decide if the gold cost is worth the convenience of getting the weapon immediately or if you’d prefer to farm and craft it yourself.
How does the Kromede Longsword compare to other weapons?
Is it better than other swords for Templars?
When compared to other swords available at level 57, the Kromede Longsword generally holds its own. The stats are well-rounded, focusing on both offense and defense. Some swords may offer higher attack power, while others may focus more on defensive stats. In general, the Kromede Longsword strikes a balance, which makes it an attractive option for many Templars. If you’re looking for a weapon that can boost your overall performance in various content, this sword is a solid choice.
Are there alternatives for crafting?
While crafting the Kromede Longsword is one option, there may be other swords or gear available through crafting, quests, or world drops that offer different benefits. For example, some players might prioritize weapons with higher attack stats or special effects, depending on their playstyle. But if you’re a Templar who values a balanced weapon that enhances both your damage output and defense, the Kromede Longsword will likely be one of your top picks.
The Kromede Longsword is a strong weapon for any Templar player in Aion 2. It’s relatively accessible through drops or crafting, and its stats make it an ideal choice for both PvE and PvP content. Most players will find that it provides a solid boost to their character’s performance and offers room for customization through manastones.
Whether you’re planning to grind for the materials and craft it, wait for a drop, or purchase it directly from the marketplace, the Kromede Longsword is a weapon worth considering if you want to improve your Templar's combat effectiveness.
U4N is known for easy Aion 2 kinah delivery: https://www.u4n.com/aion-2/kinah
Goldener
