U4GM Why ARC Raiders Coins Matter for Faster Progression
Сообщение Santiago » 08.04.2026, 11:31 »
Learn the best ARC Raiders Coins farm routes, what to sell, and how to spend smart so you can upgrade faster, lower risk, and keep your progression moving.
Coins run the show in ARC Raiders. You feel it almost straight away. If your wallet's empty, your stash stays cramped, your workshop stalls out, and every bad run hurts twice as much. A lot of players chase kills early, but that's not really what pushes your account forward. Money does. That's why some people keep an eye on places like U4GM for game currency and item support, while others just grind smarter and build up over time. Either way, the point is the same: if you want steady progress, you can't treat Coins like some extra bonus. They're the engine behind everything else.
Pick loot over fights
The easiest mistake in this game is thinking every run has to turn into a big action scene. It doesn't. If your goal is profit, you should be hunting value, not trouble. Buried City, Stella Montis, and the Dam Battlegrounds are good for one reason: lots of containers, lots of chances to pull items that actually sell. That's what matters. You're not there to fill your bag with random junk for crafting if the resale is lousy. You want the pieces with real vendor value, especially the stuff that stands out as premium loot. Once you start sorting items by what they're worth instead of what they look like, your income gets way more consistent.
Fast runs beat greedy runs
Plenty of players throw away solid loot because they stay too long. It happens all the time. They think, just one more building, one more crate, one more fight. Then a patrol rolls in, things go sideways, and the whole run is gone. A short raid is often the better play. Get in, hit the best spots, skip the filler, and leave. Five clean minutes can beat twenty messy ones by a mile if you're looking at Coins per hour. It also helps to run light. Don't bring expensive gear into a money farm unless you actually need it. The less you risk, the easier it is to keep the cycle going.
Spend like you plan to stay ahead
When Coins start piling up, it's really tempting to blow them on a flashy weapon or a loadout that looks cool in the menu. Usually that's a dead end. The smarter move is boring at first, but it pays off. Upgrade the workshop. Expand the stash. Give yourself more room and better tools so future runs are smoother. That stuff doesn't feel exciting in the moment, sure, but it quietly improves everything you do after that. Once your base is in good shape, then it makes sense to spend on stronger consumables or better gear for rougher zones. Before that, you're mostly just dressing up your losses.
Build a route you know by heart
The players who stay rich usually aren't doing anything fancy. They've just got a route, they trust it, and they run it over and over until every turn feels automatic. Maybe that's around Blue Gate, maybe somewhere else. Doesn't matter much. Familiar routes save time, and saved time means more profit. Treat each raid like a simple loop: enter, loot the best spots, leave, sell, reinvest. If you need a hand gearing up between runs, some players also look through ARC Raiders iteams while planning their next push, because staying prepared matters just as much as staying fast in a game like this.
ARC Raiders In Game Iteams For Sale:ARC Thermo Lining,ARC Coolant,[BluePrint] Looting Mk.3 (Survivor)
