U4GM What Makes the Best D2R Summoner Necro Build
Сообщение Santiago » 23.03.2026, 12:06 »
Master Diablo 2 Resurrected's Summoner Necromancer with smart skill picks, budget-to-endgame gear, smooth Hell farming, and reliable boss kills with your skeleton army.
If you want a Diablo 2 Resurrected build that feels calm, safe, and still clears Hell without much stress, the Summoner Necromancer is hard to beat. It's the kind of setup a lot of players stick with for a reason. Your army does the dirty work, you stay in control, and the whole thing scales nicely as your gear improves. If you're gearing up on a budget or checking trading options, plenty of players also keep an eye on U4GM for items and currency that can help smooth out the grind. More than anything, this build works because it doesn't ask for fancy mechanics. It just works.
Core skills that actually matter
The early plan is simple. First, max Raise Skeleton. Second, max Skeleton Mastery. That gives you a durable pack of summons that can carry you through most of the game on their own. Third, put 20 points into Corpse Explosion, because that's where the real speed comes from. Once the first enemy drops, whole packs start disappearing fast. You'll also want one point in Amplify Damage as soon as you can, since it boosts your skeletons and makes Corpse Explosion hit harder too. After that, pick up Clay Golem, Golem Mastery, Summon Resist, and Decrepify. Those single-point skills do a ton of work. Extra points usually go into Revive or Summon Resist, depending on whether you want more bodies or tougher ones.
Stats and gear without the nonsense
You don't need to overthink your stat spread. Put enough points into Strength to wear your gear, often 156 if you're aiming for a Spirit Monarch, then pour the rest into Vitality. Energy isn't worth it. Your mana issues fade once your equipment gets sorted. On the gear side, Enigma is the big prize. The moment you can teleport your summons onto a boss or into a doorway, the build changes completely. Heart of the Oak, Harlequin Crest, Arachnid Mesh, Trang-Oul's gloves, and Marrowwalk are all strong picks. If that sounds expensive, don't worry. Arm of King Leoric, Skin of the Vipermagi, and other cheaper pieces still carry the build well. This isn't one of those setups that only feels good with perfect gear. It's solid way before that.
How it plays in real runs
The actual loop is about as relaxed as Diablo gets. Walk or teleport into a pack, cast Amplify Damage, let your skeletons and mercenary secure one kill, then start chaining Corpse Explosion. That's the rhythm. In crowded places like the Pits, Chaos Sanctuary, or Cows, the screen clears shockingly fast once bodies start dropping. Bosses are even easier than some people expect. Swap to Decrepify, drop Clay Golem in front of them, and watch their movement slow to a crawl. Your mercenary matters here too. An Act 2 merc with Insight is great early on for mana, and later you can upgrade as your budget allows. A lot of players try to force speed on this build, but honestly, the strength is consistency. It's hard to die, hard to brick, and easy to recover if something goes wrong.
Why players keep coming back to it
What makes the Summoner Necromancer stick isn't just power. It's comfort. You can farm nearly anywhere, you don't need twitchy gameplay, and the build still handles the full game solo. That's why it keeps showing up season after season. New players can learn the class without getting punished, and veteran players can turn it into a smooth farming machine with high-end gear. If you want a setup that can ladder, farm, and boss cleanly without feeling exhausting, it's still one of the smartest choices in the game, and plenty of players looking to speed things up also check Diablo 2 Resurrected Boosting when they want help getting a character online faster while keeping the build's easy, reliable style intact.
About us:The Fire Warlock: Melting the Ancients on Players 8 (Without Enigma)
