U4GM Mega Pinsir ex Guide Leafeon Ramp and Will Combo
Сообщение Santiago » 06.03.2026, 11:46 »
Mega Pinsir ex hits hard fast in Grass builds: Leafeon ex ramps Energy, Will locks Critical Scissors to 150, and smart gust plays race prizes while dodging Fire matchups.
Some cards in Mega Rising feel like they were made to tempt you into bad habits, and Mega Pinsir ex is one of them. It's a Basic Grass Mega with 170 HP, hits like a truck, and then dares your opponent to take three Prizes when it finally drops. If you like keeping your lists tidy and your pickups easy, it helps to use a reliable shop for game items; as a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy U4GM Pokemon TCG Pocket for a better experience while you test builds and chase the right pieces.
Why the deck is built around one attack
You're basically signing up to win through Critical Scissors. The cost is two Grass and a Colorless, which is already asking for planning, and the attack starts at 80. Then the coin flip happens. Heads adds 70, and 150 is the real number you care about, because it deletes a ton of ex bodies that sit in that 140–160 range. Tails feels awful, because you've committed energy and tempo to a swing that doesn't close the deal. So the whole list needs to be about turning "sometimes" into "most turns," and also about not handing over three Prizes for nothing.
The core line: Leafeon ex plus Will
Leafeon ex is what makes the math work. Your best starts usually look like this: turn one you're trying to see Eevee and Pinsir on board, even if you have to bench awkwardly to do it. Turn two you evolve, and Leafeon ex does the boring but essential job—pulling Grass energy out of the deck and sticking it onto Mega Pinsir ex so you're not stuck manually attaching forever. Around turn three, Will is what flips the switch. Will guarantees your first coin flip of the turn is heads, so Critical Scissors stops being a prayer and turns into a consistent 150 when you need it. Don't fire Will off just because you can; hold it until the KO actually matters.
Finding pieces and choosing your fights
This deck lives or dies on seeing the right cards on time, so your draw suite can't be cute. Professor's Research and Erika do the heavy lifting, and you'll feel the difference when you can chain draw into your evolution plus energy acceleration without bricking. Once you're online, gust effects like Boss's Orders or Sabrina are how you stay ahead: drag up something that's already chipped, take the clean knockout, and keep the prize map in your favour. Techs are meta calls, but Leaf Cape buys turns, and a side attacker like Jolteon ex can keep you from folding when the game gets messy or your plan gets interrupted.
Matchups that punish you and how to approach them
Fire is the obvious problem, and it's not subtle. Mega Blaziken ex lines can blow through weakness and turn your three-Prize liability into a fast loss, so you've got to play like every bench spot matters and every gust counts. Hand disruption—especially Cyrus chains—can also leave you staring at a Will you can't use or a Leafeon you can't evolve into, which is why you mulligan hard for setup and don't over-bench dead cards. Big tanks like Guzzlord ex can survive 150 and hit back, so sometimes the "smart" play is taking two smaller KOs instead of trying to punch through one wall; if you want a quicker way to jump into testing or switching builds, it can be convenient to sort your collection through Pokemon TCG Pocket Accounts before committing to a full grind in tougher metas.
