Fast ARC Raiders coin guide for 2026: loot high coin-per-slot trinkets, run quick Buried City and Dam routes, extract on timers, farm night modifiers, and spend smart on stash and augments.
If you're running Speranza in 2026 and still stuffing your bag with random junk, you're basically paying stamina to stay poor. Coins are the real progression gate now, so your looting has to be picky. Think coin-per-slot, not "anything that isn't nailed down." Small high-value trinkets, especially diamond pieces, are king because they stack and they don't slow you down. If you're short on time or you're trying to catch up, some players also top up via U4GM for currency and item services, but even then you'll get more out of your runs if your inventory discipline is solid.
Loot rules that actually work
Start with a simple filter and stick to it. 1) Prioritise compact valuables: gems, rare components, anything that stacks. 2) Treat low-tier scrap like it's optional, because it is. If it's selling under 2k, you're often better off breaking it down on the spot into metal or rubber and moving on. 3) Protect your slots for "sure money" items. People love grabbing a bulky pipe or busted machine part, then wonder why they're waddling to extract with half the value they could've had. You'll notice your average haul jumps the moment you stop "just in case" looting.
Fast routes and when to bail
The Buried City Library is still the easiest warm-up when you want quick cash with low drama. Hit lockers, skim desks, don't overclear, and take the train out. You can do it in under six minutes if you don't get distracted, and the run's often a clean 20k. When you want a bigger payday, go Dam Research floors and work the offices. Close doors behind you. It buys you seconds, and seconds keep you alive. Ten minutes can be 50k, but only if you've got an exit plan. Set a timer. Seriously. Most deaths happen after the "one more room" decision.
Modifiers, probes, and avoiding sweaty fights
Night raids can feel rough because ARC patrols hit harder and you'll hear fewer footsteps, but the rarity bump is real. A suppressed pistol and patience go a long way. Prospecting Probes are also worth building your route around; they pull you toward higher density loot without you wandering. If your lobbies are turning into constant third-party chaos, rotate your schedule. A lot of Raiders swear by quieter hours for Library runs and leaving Dam for later when the heavy hitters are busy elsewhere.
Loadouts and spending without regret
Farm runs aren't a fashion show. Go light, bring Hatch Keys, and lean into inventory augments so you're not forced to choose between value and survival. In squads, don't all pile into the same closet-sized office; have one person watch lanes while the others clear, then swap. Back at base, spend quickly: roughly 40% into stash space, the rest into inventory upgrades and premium Vita Shots, and skip flashy craftables unless you're flipping a vendor special. If you're tracking your growth, it also helps to know what a top-up looks like on ARC Raiders Coins so you can compare the time you're saving against what your best routes are already earning.
