ARC Raiders coin farming: run safe interior loops on Buried City and Dam, target diamond trinkets and compact purples, watch Night Raid modifiers, keep coin-per-slot high, and extract early for 200k-300k per hour.
Chasing random drops in ARC Raiders feels fun for about ten minutes, then you realise you're just feeding other squads. What actually pays is simple: think in coins per slot, not "nice, I found something." Grab purples and yellows, ditch chunky greens, and don't get sentimental about crafting junk. If you want to skip some of the early grind, plenty of players also look at places like U4GM for game currency or items, but your day-to-day profit still comes from clean routes and fast exits.
Buried City Library Loop
If you're solo or lightly geared, start here. The Library loop is quick, and quick equals safe. Sprint to the yellow POI, get inside, and stop staring at every container like it's a museum. Lockers, desks, and that little audio chime for high-value trinkets are what you're listening for. Hit the main reading room, then swing back through the offices for safes. If it's busy, don't "wait it out." Just peel off to Grandioso Apartments and use the stairs and weird angles to break line of sight. When you see Lush Blooms on the deployment screen, run the loop again and again because the organic drops stack up fast.
Dam Battlegrounds Mid-Game Cash
Once you've got a half-decent kit, Dam Battlegrounds becomes your steady earner. The Hydroponic Dome Complex takes longer, sure, but it's reliable money because fertilizer stacks sell well and don't eat your whole backpack. ARC density is manageable too, which matters when you're trying to loot instead of doing a drawn-out firefight. Link the domes into the Testing Annex offices for electronics and rare parts, then leave. If a Husk Graveyard event pops, you can gamble on it for epic drops, but treat it like a drive-by: in, loot, out, no hero plays.
Spaceport Burst Runs
Spaceport is where you go when you're ready for sweat and big spikes. Rocket Assembly into Control Tower B6 is a strong line, but you've got to keep moving. Hangars first for mechanical heavies, then take ziplines and use vertical routes to avoid getting pinned by mortars. Shields aren't optional here. I like dipping into Container Storage to top up on trinkets, then extracting before the whole area turns into a queen-themed panic. Stack contracts when you can, and sell with intent—if it's not beating your best coin-per-slot, it's dead weight.
Keeping Your Runs Consistent
The trick is knowing when to leave, not how long you can stay. Always scan modifiers before you drop; Night Raid and Electromagnetic Storm can bump loot tiers enough that you should go in a bit heavier and plan a safer exit line. Keep your bag sorted as you move, so you're not doing inventory Tetris while footsteps get louder. And if you're swapping builds or want a fresh start without the slog, some players even shop for ready-to-play profiles like ARC Raiders Accounts while they keep learning these routes and timing their extracts properly.
Contatc us:Mastering Surveyor Vaults in ARC Raiders: Proven Farming Strategies That Actually Work
