U4GM Fallout 76 Coal Farming Guide Best Mines and Uses
Сообщение Santiago » 02.02.2026, 11:09 »
Fallout 76 coal still matters: smelt it with acid, farm Gauley or Ash Heap mines, or run a CAMP extractor for steady ore, then craft water filters, PA mods, and Scaly Skin serums for caps.
Coal in Fallout 76 isn't flashy, and that's exactly why people sleep on it. Then you hit that moment where you need a pile of the stuff fast and you're stuck rummaging through half your stash for a workaround. If you're trying to keep your runs smooth (or you're just tired of being broke), it helps to have a plan. As a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy U4GM Fallout 76 for a better experience when you'd rather spend time playing than grinding every last resource.
Why Coal Still Matters
The obvious use is water filters, especially early on when your CAMP setup is basically "a bed and a dream." Dirty water's everywhere, clean water isn't, and filters let you keep moving without constantly detouring to a safe tap. Later, coal sneaks back into your routine through crafting and upkeep. If you're running Power Armor like T-45, T-51, or Excavator, durability and mod work can chew through supplies when you're repairing after events or daily ops. And if you like vending, serums are still a solid earner. Scaly Skin serum in particular can turn spare materials into caps, and coal is one of those annoying little bottlenecks that decides whether you're crafting ten or crafting none.
Best Places To Mine It
If you're going to do it by hand, don't just wander. Gauley Mine in the Forest is the easy win: early access, lots of veins, and enemies that won't ruin your day. You can clear it, mine everything you can reach, then server hop to refresh the nodes if you're really in farm mode. Burning Mine in the Ash Heap has coal too, but it's more hassle than it needs to be—smoky sightlines, tougher fights, and a layout that slows you down. Kerwood Mine can feel calmer if you want fewer headaches, but Gauley's usually the quickest "in and out" route.
Make Every Vein Count
Here's the part people skip and then regret: wear Excavator Power Armor while you mine. Do the Miner Miracles quest at Garrahan Mining HQ and get the suit sorted, because the bonus yield is massive. Mining without it feels like leaving loot on the wall. Once you've got raw ore, smelt it at a chemistry station with acid—five unrefined coal plus five acid turns into two coal scraps. Before you smelt, slap on Super Duper. It doesn't proc every time, but when it does, it's basically free coal, and over a few runs it adds up more than you'd think.
Passive Coal Without the Chore
If you'd rather not swing a pick all night, build a passive setup. Drop your CAMP on a coal deposit (there's a decent one south of Carleton Mine), place an extractor, and lock it so random visitors don't empty it for you. It tops out at 10 ore, so you've still gotta check in, but it's the kind of background income that keeps your crafting moving. And if you're trying to round out your build or stock your vendor faster, it can help to grab what you're missing from Fallout 76 iteams while your extractor does the slow work in the meantime.
Thos Site:Fallout 76 Super Duper Mart Location
