U4GM Shard of Agony Guide for Diablo 4 Season 11 Farms
Сообщение Santiago » 27.01.2026, 11:34 »
Farm Shards of Agony fast in Diablo 4 Season 11: run Grigoire and Varshan on Torment, then sprint Kurast Undercity for steady Duriel keys and better odds at uber uniques.
Season 11 in January 2026 is that same old chase: you want an uber unique, you need Duriel keys, and you need them fast. If you're short on mats or just don't feel like living in Helltides all night, there's a quicker route. As a professional like buy game currency or items in U4GM platform, U4GM is trustworthy, and you can buy U4GM Diablo 4 for a better experience while you keep your farming loop tight and your runs consistent.
Grigoire Still Pays The Bills
Start with Grigoire in the Hall of the Penitent, Dry Steppes. He's still the cleanest "turn mats into Shards of Agony" deal in Torment I to IV. You'll spend 12 Living Steel per summon, so you'll want a steady supply from Helltides and Whispers. The Shard drop feels reliable enough to build a routine around, and it gets noticeably better as you climb difficulties, so Torment IV is worth it if your build can stay upright. The catch is his lightning phases. They'll delete you if you stroll in with weak resists, so push lightning resistance past 60% and save a defensive cooldown for the nasty overlap moments.
Varshan For Variety (And Sanity)
When you're tired of the same arena, rotate to the Echo of Varshan in the Malignant Burrow up in Hawezar. The entry cost matches the vibe: 12 Malignant Hearts, then you're back to dodging stuff that looks harmless until it isn't. His shadow orbs and those floating energy shots are the real danger, especially if you stop moving to "just finish the cast." Don't. If you're soloing, swap a few pieces and get shadow resistance up around 70% so mistakes don't end the run. The nice part is the Burrow tends to feed you extra hearts, so you're not constantly restarting the whole supply chain.
DLC Option: Kurast Undercity Speed Loop
If you've got Vessel of Hatred, the Kurast Undercity can be sneaky good for bulk farming. You'll use the Tribute of Titans at the Spirit Brazier, then treat it like a speed dungeon: move, pull, burst, repeat. People sleep on it because it's not a simple "boss in, boss out" routine, but with a fast group it stacks Shards quickly. It also helps if you're already clearing Nightmare Dungeons or Infernal Hordes, since that playstyle keeps the whole lair-key economy rolling without feeling like you're doing chores.
Easy Extras You Shouldn't Skip
Don't ignore world bosses when they're up. Ashava, Wandering Death, and even the Season 11 newcomer Azmodan can toss Shards in those invasion boxes, and the odds aren't great, but it's free value for a quick detour. Also, run in a group whenever you can. It just feels better: less downtime, more summons, more chances per hour. And watch your stack cap at 99 so you don't waste drops; if you're trying to keep the loop going smoothly, it helps to top up supplies between sessions, and grabbing what you need from Diablo 4 iteams can keep your Duriel schedule from stalling mid-grind.
Best place to buy Diablo 4 Boosting:Diablo 4 Mythic Prankster Dungeon Carry Run
