Speedrun Strategies: Fast Ways to Secure a Cowardly Fate in
Сообщение Santiago » 18.08.2025, 09:41 »
Getting Cowardly Fate quickly is essential for progressing through the Trial of Chaos and eventually facing the Trialmaster boss. This powerful fragment is dropped by Uxmal, The Beastlord, at the 10th round of the Trial and requires efficient farming strategies and build optimization to acquire rapidly.
1. Optimize Your Character Build
Success depends heavily on balancing speed, damage output, and survivability:
Movement Speed: High mobility helps you navigate trial arenas quickly and dodge boss mechanics.
Area of Effect (AoE) Damage: Effective mob clearing means less time spent on each wave.
Defensive Layers: Invest in life, energy shield, or evasion to survive intense boss fights and environmental hazards.
Crowd Control: Skills that slow, stun, or immobilize enemies improve survivability and reduce damage taken.
2. Focus on Appropriate Inscribed Ultimatums
Run Inscribed Ultimatums with area levels around 76 or higher. This level strikes a good balance by providing solid rewards without being overly difficult to clear. If your character is powerful enough, farming area level 80 Ultimatums can yield even better item and fragment drops.
3. Use Citadel Maps and Atlas Optimization
Citadel maps are key gateways to Trials of Chaos. Prioritize passive skills on your Atlas that boost Citadel map drops and fragment rewards. Utilizing map modifiers that increase item quantity and rarity further maximizes loot per run.
4. Consistent, Safe Farming
Maintain steady runs rather than rushing and risking death. Efficient clears will yield more fragments per hour. Be sure to prepare for trial-specific mechanics, such as escorting statues or handling additional enemy spawns.
5. Inventory and Currency Management
Regularly sell valuable drops like Deadly Fate fragments and soul cores to keep a strong currency flow. This lets you afford more Inscribed Ultimatums for faster farming cycles.
6. Target Trialmaster Boss Runs
If you can reliably reach and defeat the Trialmaster, farming its unique rewards alongside Fate fragments offers high profits and faster accumulation of key items.
These speedrun strategies, focused on optimizing your build, map choices, and farming consistency, help you rapidly gather Cowardly Fate fragments. With practice and the right setup, you can secure these valuable fragments efficiently and push forward confidently in Path of Exile 2’s endgame content.
