The Test of Cunning Barya is a key component of the Trial of the Sekhemas in Path of Exile 2, representing the final and most demanding challenge within this trial series. It requires players to demonstrate not just raw power but sharp perception, agility, and strategic movement—qualities embodied by the Sekhemas creed that “strength can be outmatched by move and countermove.”
This test is accessed by placing the Test of Cunning Barya, a special Sekhemas Coin, on the Relic Altar at the start of the trial run. The coin itself is a rare, randomly found item that grants trial bonuses, making the challenge more manageable and enhancing the rewards upon completion. The trial’s design focuses heavily on environmental hazards such as fire jets, spike traps, and pressure plates that demand precise timing and positioning to avoid damage. Unlike earlier tests that emphasize brute strength or endurance, the Test of Cunning pushes players to outthink and outmaneuver obstacles.
As the trial progresses, players accumulate afflictions—debuffs that hinder movement, damage, or resistances—while their shared Honour pool diminishes with each hit taken. This escalating difficulty forces a balance between speed and caution, as reckless movement can quickly lead to failure. The final encounter pits players against Ashar the Sand Mother, a challenging boss who requires sustained mobility and consistent damage output to defeat.
Success in the Test of Cunning Barya hinges on high mobility and survivability. Builds that excel often feature movement skills like Flame Dash, Whirling Slash, or Blink Arrow, enabling players to quickly dodge traps and reposition during combat. Summoner builds also perform well by using minions to tank damage and clear enemies safely, allowing the player to focus on navigation. Defensive stats such as evasion, life, and resistances are crucial to withstand unavoidable hits and afflictions, while utility flasks that grant immunity or quick recovery provide essential survivability.
Strategically, players must plan their path through the trial carefully, observing trap patterns and timing their movements to avoid damage. Choosing appropriate relics and pledges that boost survivability or reduce trap damage can significantly ease progression. Patience and practice are vital, as familiarity with the trial’s mechanics and layout greatly improves success rates.
The Test of Cunning Barya is a trial that tests a player’s ability to combine perception, agility, and tactical decision-making. It challenges players to move thoughtfully and strike a balance between offense and defense, embodying the Sekhemas ideal of cunning over brute force. Mastering this trial not only unlocks powerful Ascendancy rewards but also marks a significant achievement in Path of Exile 2’s endgame journey.
