Best ARC Raiders coin farming guide: fast Buried City, Dam and Spaceport routes, top trinkets to sell, smart recycling tips, and safer extracts for steady profits.
Coins run the whole show in ARC Raiders. You need them for stash upgrades, gear tweaks, keys, and all the little things that quietly drain your wallet. The fastest way to build a healthy stack usually isn't some wild one-off run. It's repetition. Clean routes. Quick exits. If you've ever checked prices, compared loot, or even looked at trading options on U4GM, you'll already know that steady value matters more than flashy risk. That's why the smartest farming paths are the ones that give you solid loot every run without forcing you into messy fights you didn't ask for.
Start with Buried City
If you're still learning the maps, Buried City is probably the best place to settle in. It's compact, easy to read, and packed with enough containers that even a short raid feels worth it. The Library is usually the safest opening. You can move through fast, scoop up commercial loot, and get out before the area turns noisy. After that, I like pushing into the Research District for tech parts. Not always glamorous stuff, but it sells and it adds up. The Galleria is where people get tempted. Fair enough, because the trinkets there can be huge money. But it's also where things go sideways fast. A simple Library-to-Research loop with an exit through the Parking Garage is boring in the best possible way. That kind of route can carry your coin total far more reliably than chasing one giant run.
Move up to Dam Battlegrounds
Once you're comfortable taking quicker decisions under pressure, Dam Battlegrounds starts to make more sense. The real draw is the Research and Administration Offices. Those buildings are stuffed with office loot, drawers, shelves, and dense clusters of containers, so your bag fills quickly without needing to cross half the map. You'll also find decent mechanical loot around the Hydroponic Dome and the Power Generation Complex, which helps if you want parts that hold value without taking up too much room. What matters here is timing. Stay disciplined. Ten to twelve minutes is usually enough. Past that, the map feels different. More movement, more danger, worse odds. People often lose profit not because the route failed, but because they got greedy and stretched a good raid into a bad one.
High risk runs at Spaceport
Spaceport is where the numbers get serious, but so does the punishment. If you go there, go prepared. Rocket Assembly and Control Tower B6 can spit out incredible tech loot, the kind of stuff that can swing a run in a hurry. On event timers, especially around launch activity or storms, the area gets even hotter and richer at the same time. That sounds great until another squad has the exact same idea. You've got to loot with purpose there. No wandering. No second-guessing every crate. Hit the key rooms, take the high-value pieces, and leave before the map turns into a brawl you can't win. Spaceport can make you rich, sure, but it also punishes sloppy decisions harder than any beginner zone ever will.
What actually keeps the coins flowing
The little habits matter more than most players think. Prioritise diamond-icon valuables first, because those are pure sale value and they don't depend on crafting plans or future use. Items like novelty trinkets, rare collectibles, and compact tech pieces are often better than bulky junk with average resale. Use your field recycler when your inventory gets awkward. It saves runs. Also, keep checking your value as you move, because that number tells you when it's time to stop pretending there's “one more room” worth looting. Most players build wealth by surviving, not by gambling. If you want to save time, sharpen your route planning, or get extra help through ARC Raiders Boosting while still focusing on safe extractions and smart inventory choices, the real trick is staying consistent and leaving with profit before the raid asks for more than it's worth.
